Author Topic: Larger throttle body? Info? Power gains  (Read 16963 times)
tim_s
« Reply #30 on: June 10, 2007, 04:25:51 AM »
just to add my experiences. bigger throttle body gives a little more on full throttle but really is a bit of a waste of time - you'd be hard pushed to tell the difference. i have the same +4mm one that omi has, ian (alpina357 on uk forums) uses an engineer friend of his to add a 4mm larger butterfly to the large butterfly, the body is nicely drilled and ported to flow with it. it's nice to have a recon'd unit though, it opens very smoothly etc.
SMT6 = waste of time. Didn't work well with our AFM. I also tried to use it for a MAP conversion, this was tedious and didn't work that well.
MS is very good. I'm now running an MS2 extra which is even better. I don't agree with bmwman about the gains on a standard M42, I fitted MSNS+HR on dan318is' standard M42 a few months ago, and just running an old map of mine it feels more lively, faster with better response.
When I had my 1.8 on the rollers, I managed to squeeze nearly 10hp on factory by using megasquirt, and that's not the whole story - throttle response etc was much better.
I agree on it being a pita to get the hang of, but once you know what you're doing you can come up with good maps in no time.
2.1 200bhp, 175ft/lbs 318is
E46 330ci daily
ose30
« Reply #31 on: June 10, 2007, 03:52:38 PM »
Quote
SMT6 does not work well with MAP sensors, this is a well known problem. With MAF sensor it works much better.
nickmpower
« Reply #32 on: June 10, 2007, 04:21:14 PM »
Quote from: tim_s;27501
are you interestid in selling the TB? seems like you wouldnt have a use for it
Royalratch
« Reply #33 on: September 27, 2007, 04:24:31 PM »
So what's the verdict here? Big bore is a waste of time?
I'm doing a re-map for my M44 and was going to throw a bigger throttle in but now I'm not so sure?
« Reply #34 on: September 27, 2007, 05:12:43 PM »
Was the 10hp gain versus a stock chipped M42?  A Conforti chip adds almost that much power.
Now as far as all the other benefits of stand-alone and a MAF I totally agree.  The car feels better than new with the MAF on there as far as liveliness.  On a stock-internal M42, the AFM flows enough.  On a modified engine, you might want to consider ditching it.
steinkek
« Reply #35 on: September 27, 2007, 05:54:16 PM »
Wow im a noob and you guys have me so lost.......what is megasquirt?
MS and MS2??
jpod999
« Reply #36 on: September 27, 2007, 06:19:00 PM »
MS stands for MegaSquirt.  MS2 stands for MegaSquirt 2.  Megasquirt is custom tunable ECU I believe.  It's known to be cheaper than the big company names.
tim_s
« Reply #37 on: September 28, 2007, 02:19:13 AM »
Quote from: bmwman91;34476
yeah, was about 7hp at the wheels iirc, something like that, was a few years back now! and yeah i don't doubt that a chip would do pretty much the same! A good chip i'm sure would do pretty much exactly what we altered on the rollers - i suppose the difference is it's not off-the shelf and will be spot on for your actual car etc., also I use EGO control and AFR targetting, so i know it will get that optimum AFR every time.
E46 330ci daily
black318i
« Reply #38 on: November 01, 2007, 01:15:43 PM »
Quote from: Royalratch;34469
1+
I'm thinking about doing this, but I don't want to wast my money. I'm keep my AFM for smog reasons. Right now I have a DASC and exhaust. I have a unichip wired up but not installed with a good base map that needs some fine tuning.
« Reply #39 on: November 01, 2007, 02:08:48 PM »
There was a guy over on bf.c. who had a dinan TB on his m42. Anyone heard of this?
black318i
« Reply #40 on: November 03, 2007, 12:26:23 AM »
I read that tread a while ago and I’ve been trying to find it. I remember he did say throttle response was better, but I can’t remember if it was installed on an m42 or m44
« Reply #41 on: November 03, 2007, 05:30:30 PM »
It was on an m42, and he didn't even realize it was on the car until he took the intake apart to clean it or something.
DutchM42
« Reply #42 on: November 04, 2007, 07:36:18 AM »
I have the Alpina527 enlarged throttlebody. To be honest, I don't feel any difference. A friend of mine put one on his M43B19TU and had a superb increase in throttle-response.
I think the M42 TB already flows enough air.
I had the chip replaced, and that made a big difference. Better spend the money on a good remap.
Royalratch
« Reply #43 on: January 12, 2008, 05:25:21 AM »
So M42 TB's are different to M43/M44?
