Author Topic: E30 M3 Flywheel conversion  (Read 6340 times)
e30nut
e30 m3 Flywheel coversion - no go
« Reply #15 on: June 11, 2007, 07:04:40 AM »
Alas, it's not meant to be.
Turns out the ring gear on the M42 FW has just a hair smaller ID than the e30m3 ring, so it's NOT going on there. The OD is significantly smaller on the M42 FW. So, the starter gear was trying to engage, but it butted up against the larger ring of the e30m3 FW and sat there, spinning.
It's conceivable that it might work if you had an e30m3 starter (or a starter gear swap), but that's not happening.
I've spent entirely too much time on this project in the middle of an engine swap. Oh well, stock will have to be good enough for the DD.
cheers!
jpg
98 M3/4 :)
91 318is :mad:
90 325iC :cool:
88 M3 :D
ose30
« Reply #16 on: June 11, 2007, 10:16:09 AM »
how about hall sensors located on the flywheel? Does this swap effect to them? I suppose Motronic will go nuts if there is adifference compared to original setup.
m44power
« Reply #17 on: June 11, 2007, 11:19:31 AM »
hall sensors isn't on flywheel is on the pulley im running m20 euro 320i flywheel and it works perfect exept my starter gear :p too noisy (im an auto electrician :D someday im gone fix my car too :p)
Abrax
« Reply #18 on: June 11, 2007, 12:23:43 PM »
Quote from: e30nut;27550
cheers!
jpg
DUDE - DONT GIVE UP!!!!
I've just read this thread very carefully and theese are my aids:
I'd try to measure the distance from the middle of the crank hole to the middle of the starter hole - if they are identical /what I think is true/ in both engines /S14 compared to M42/ just change Your starter from the M42 one to S14 one... It should fix the problem of missing teeth... Of corse there is another question - how deep the starter teeth dive to reach the FW teeth on both engines...
And BTW S14 is based on the same block as M10 is /we've already checked this/ so M10 starter fits S14 /we've tested this when S14 starter broke down/ So the cure is to put there M10 starter, not the S14 /which is rare or more expencive/.
I had the same idea of swapping the M42 with S14 FW, but I didn't start to do it yet. But anyway I wouldn't start anything untill measuring the two engines well... Pulling out the FW is not very easy job, to do it over and over again...
I'd rather pull the tranny away and than try to fit the FW on the crank, and make it work well, checking if it works w/o tranny at all... It is safe, but You have to keep the engine stable when the launching is happening. And of corse fire it up w/o the cluth mounted on!!!
There is also the risk of braking the teeth easily, when they don't dive deep enough to reach the FW teeth completely, but You can wire the starter just partially w/o starting the starter at all...  It should show You if the depth is correctly applied.
To correct the depth, I'd use spacers or make the starter mountings machined to decrease the depth /if needed/. Just have to check the depth.
Feel free PM me if You need any more info...
« Last Edit: June 11, 2007, 12:29:53 PM by Abrax »
560 km in 3 hours and 5 minutes completely legal!!!                  I love german highroads!!!
Abrax
« Reply #19 on: June 11, 2007, 12:55:39 PM »
cheers!
jpg
You have to measure few distances:
1. The one between the middle of the crank hole to the middle of the starter hole - You have to check the S14 compared to M42 engine...
2. If they are the same, measure the FW diameter, if this is the same,
3. Check how deep the starter teeth dive to reach the FW teeth on both engines...
If any of those measures differs from another engine, It is a must to change the mounting points to set them just in the same corelation /i mean starter with the FW/...
And BTW S14 is based on the same block as M10 is /we've already checked this/ so M10 starter fits S14 /it wont work with the S14 because of the manifold, but it has the same mounting measures... So maybe the cure is to put there M10 starter /it has to have the same teeth as S14 starter/, not the S14 /which is rare or more expencive/.
I had the same idea of swapping the M42 FW with S14 FW, but I didn't start to do it yet. But anyway I wouldn't start anything untill measuring the two engines well... Pulling out the FW is not very easy job, to do it over and over again...
I'd rather pull the tranny away and than try to fit the FW on the crank, checking if it works w/o tranny at all... It is safe, but You have to keep the engine stable when the launching is happening. And of corse fire it up w/o the cluth mounted on!!!
I'll check my setup tomorrow because I have the parts out of my car. I will check the simillarity of the two FW /the M42 one and S14 one/ and post a sollution if I'll find one...
Abrax
« Reply #20 on: June 13, 2007, 12:55:02 AM »
Yesterday in the evening I've realised that starter mountings are in the tranny rather than in the engine block.... So it is not that easy to check everything w/o tranny... - Sorry for the mistake...
