Lightweight Flywheel Options
Author Topic: Lightweight Flywheel Options  (Read 8135 times)
Wise Old Dog
« Reply #15 on: May 28, 2007, 05:14:48 PM »
Yes it does, and not much noise because of it.
anisotropy
« Reply #16 on: May 28, 2007, 05:25:01 PM »
What's involved in lightening a flywheel? apart from getting a machine shop you trust to shave a few kilos off it, do you have to get the thing balanced to your engine afterwards or just swap it over when you change the clutch and drive off with a big smile on your face?:D
Wise Old Dog
« Reply #17 on: May 28, 2007, 10:09:43 PM »
Cost me $100 to machine and balance at a local speed shop. Swap it.
b318isp
« Reply #18 on: May 29, 2007, 08:31:59 AM »
M42 clutch and pressure plate works with the M40 flywheel without mods.
Wise Old Dog
« Reply #19 on: May 29, 2007, 08:39:46 AM »
Only the non-AC clutch assembly will work with the single mass flywheel. AC cars have the dual mass flywheel. Totally different clutch used on each model.
« Reply #20 on: May 29, 2007, 03:27:58 PM »
How much is the M40 flywheel? I know JB racing sells a sprung-hub aluminum flywheel here
For all the people who would like a lightweight flywheel for the M42, I'm suprised that there aren't more options...
Wise Old Dog
« Reply #21 on: May 29, 2007, 03:47:51 PM »
Keep an eye on e-bay. I found mine for $50, $25 shipping. I've seen others since then.
anisotropy
« Reply #22 on: May 30, 2007, 06:33:20 AM »
Quote from: Wise Old Dog;26741
I've a quote for about £60, but they say they need the crankshaft to balance it - didn't realise this -do you need to remove your crank for them so they can 'run it on the balancer' :confused:
« Reply #23 on: May 30, 2007, 06:44:05 AM »
^^ sounds like a bit of BS to me, one of the machine shops I talked to said that they have a machine that more or less "simulates" having a crank hooked to it.
