Author Topic: Need Help Fast  (Read 2212 times)
thebigbadyeti
Need Help Fast
« on: May 15, 2007, 04:32:28 PM »
Ok so i was trying to find the source of a sneaky oil leak and noticed that at the cam position sensor, it seems wet... I  further noticed the wiring conduit for the crank sensor is mounted on the INSIDE of the cam sensor. Is this correct or should it be on the OUTSIDE of the sensor? can someone post a photo of their cam position sensor ... or maybe some one knows off the top of their head? thanks
Need Help Fast
« Reply #1 on: May 15, 2007, 05:03:16 PM »
Upper front cover just below the valve cover. #6
http://realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_2683&hg=11&fg=10
#11
http://realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_0156&hg=11&fg=10
both wires run in a channel around the front of the motor. The cam sensor should go into the front cover by itself.
« Last Edit: May 15, 2007, 05:08:10 PM by D. Clay »
thebigbadyeti
Need Help Fast
« Reply #2 on: May 15, 2007, 05:07:54 PM »
you have been most helpful. Thank you
« Last Edit: May 15, 2007, 05:52:34 PM by thebigbadyeti »
