DISCUSSION
Engine + Driveline
318is Steering Wheel Hub Adapter
Topic: 318is Steering Wheel Hub Adapter (Read 2924 times)
badboypolar
April 18, 2007, 03:53:35 PM »
I'm unsure which adapter to purchase to install my Grant steering wheel. The 318is has an air bag and I don't think the normal E30, until 90, will work correctly. I'm specifically looking for a Grant unit but will buy a MOMO or other if I have to.
Last Edit: April 18, 2007, 09:01:44 PM by badboypolar
jpod999
Hero Member
April 18, 2007, 05:21:17 PM »
To put on an Mtech 1/2 you just need to put in a spacer I have heard. I don't know about aftermarket wheels though.
Thanks to Brad at
http://img443.imageshack.us/img443/7567/ticevalleysiggv7.jpg
">Shutterflick.com for editing the sig.
e9nine
Hero Member
April 18, 2007, 07:39:38 PM »
You don't need any specific hub adapter. You can either use a non-airbag contact ring with some washer(s) or retain your airbag contact ring contact ring with washers.
You need the contact ring to still have a function turn signal return function along with a functioning horn.
G.Luck
badboypolar
April 18, 2007, 09:02:26 PM »
Sorry guys, I forgot to mention I want to install an aftermarket steering wheel.
Alpine003
Hero Member
April 18, 2007, 09:30:43 PM »
Grant = 5 bolts
Momo/Sparco = 6 bolts
Just get any hub from any '84-'91 3 series and you should be good.
Parts for sale:
http://www.m42club.com/forums/showthread.php?p=19956#post19956
e9nine
Hero Member
Reply #5 on:
April 18, 2007, 09:32:18 PM »
FWIW My Momo wheel came with a hub and it has been plug and play replacement for both air-bag and non-airbag cars with all functions retained.
DISCUSSION
Engine + Driveline
