Author Topic: adjusting timing gears  (Read 3290 times)
logger
« on: April 07, 2007, 09:37:23 AM »
Being that the m42 timing gears are adjustable how do you set them up ?
1991 E30 M42
« Reply #1 on: April 07, 2007, 01:28:35 PM »
Thats a very broad question. Be more specific on what you want to do.
logger
gears
« Reply #2 on: April 07, 2007, 01:30:14 PM »
Just put new cams in and want to know where to set them to ?
« Reply #3 on: April 07, 2007, 02:14:31 PM »
There is a special tool to hold the cams in place and then you tighten the bolts that hod the gears. See:
http://www.m42club.com/forums/showthread.php?t=1500&highlight=special+tools
http://www.m42club.com/forums/showthread.php?t=121&highlight=special+tools
« Reply #4 on: April 07, 2007, 02:25:56 PM »
I have also heard that there is a slight performance gain from advancing the intake cam a few degrees - 5, I think. Looking at the motor from the front, after loosening the cam gear bolts, which way would you rotate the cam to advance it?
Has anyone done this? If so, is there any gain?
kowalski
  • El\' Duder
« Reply #5 on: April 07, 2007, 04:08:46 PM »
there is a slight gain up top. but losses down below. so its a tradeoff. and its not worth it. you also don't need the "alignment tool" to align them.
Sale:
Fore Sale Thread
logger
timming gears
« Reply #6 on: April 07, 2007, 10:14:23 PM »
If you take off your timming gears and do not mark them how do you know were to align them again ?
2002maniac
« Reply #7 on: April 07, 2007, 11:00:47 PM »
put a straightedge across the flats on the rear of the camshafts.  get the slack out of the chain and set them there.
badboypolar
« Reply #8 on: April 07, 2007, 11:03:13 PM »
That's a what I did eh.
logger
align cams
« Reply #9 on: April 08, 2007, 10:44:56 AM »
Ok so that is at zero than I did machine that tool used for alining cams .
