Author Topic: Central Locking Question  (Read 8040 times)
« Reply #15 on: June 09, 2006, 01:02:12 PM »
Quote from: Tonyb
Central locks were standard on the 91 318i and is. The only options for both models in 1991 were LSD, fog lights, sunroof, anti-theft, and metallic paint. Ellisoid lights could be had as a dealer upgrade. I found the info in Car and Driver(Sept. 1990) I also have MotorTrends Sept. issue with thier 318is write up. I will try to scan them for posting soon!
FYI, Febi has already done so. Link to the scan HERE
mikesjo
« Reply #16 on: June 09, 2006, 08:22:55 PM »
We've had 3 318iss. All have had central locking. On one car the actuators went :). So that is probably the problem. If the trunk one dies, I think they all go as well.
Tonyb
Car & Driver 318is review
« Reply #17 on: June 09, 2006, 08:37:04 PM »
Febi only posted M&T, I have Car & Driver.
johna
    • My BMW 3 Series Website
« Reply #18 on: June 09, 2006, 09:22:32 PM »
For standard features and options see the autotrader.com web site.
« Reply #19 on: June 09, 2006, 11:39:19 PM »
Quote from: Tonyb
Oops, do you have these in high resolution by any chance?
Tonyb
« Reply #20 on: June 10, 2006, 12:46:06 AM »
I'm working on it.
RED IS 91
« Reply #21 on: June 11, 2006, 10:07:15 AM »
My central locking worked  to a few days ago .
Now I can hear a click click but nothing happens .:confused: :confused:
Low on the priority list but would be nice if it worked ...........
318-is
« Reply #22 on: June 11, 2006, 03:06:49 PM »
The most common failure on central locking on e30s (before i start, all Is have central locking from factory) is the locking ECU itself, which on euro cars is located in the drivers side (passengers side for american guys) footwell, behind the speaker cover, and is held in place by 2 x 8mm bolts. replacing this often fixes a lot of problems.
Another common fault is that from the factory, one of the wires leading to the motors themselves was a constant live, even with the ignition off. This meant over time, corrosion to the motor/wire itself was an issue. often a good fix is to pull up the drivers (again, to the american guys, passengers footwell and locate three wires, one of which is red. with the central locking ecu and loom removed, follow the red wire to this location and dont loose it. then, locate the socket for the interior light delay relay, and locate the solid red wire that goes into the relay socket. Cut this wire, and also cut the red wire located earlier, and join the two. This will solve about 80% of locking problems.
If the door pins cannot be operated, and none of the motors can be operated even by using the key, then the locking motors themselves have burnt out. Although there is a mechanical fuse in the central locking ECU itself to stop this form happening, the fuse itself runs on a heat basis. basicaly, if water contamintaes your central locking ECU and cools this fuse, your motors will burn out and will need to be replaced.
Firstly check fuse 27 though!
HTH
« Last Edit: June 11, 2006, 03:12:32 PM by 318-is »
