Author Topic: Some M42 FI Affection  (Read 10999 times)
Tor Arne Kaasen
« Reply #15 on: August 08, 2007, 02:23:32 AM »
Hi Rob e30. do you use GT2871R to get that kinde of power? ore some other type. is the car 1,8 liter 109 cdi?
BMW E82 120d Coupe and BMW Z3 1,9 m44
BrandC
« Reply #16 on: August 08, 2007, 06:18:43 AM »
VIDEOS, more of them and faster.
« Reply #17 on: August 08, 2007, 08:07:32 AM »
Quote from: BrandC;31214
Haha
Where have you mounted the intercooler?
rob_e30
« Reply #18 on: August 08, 2007, 10:15:51 AM »
Quote from: Tor Arne Kaasen;31212
The turbo is bigger than the 2871 and the displacement is more than the stock 1.8L.  It's under 2.0L with a GT3071.
I'm kicking myself for not taking a video while it was running last night.
Here is a pic of the new front end...
« Reply #19 on: August 08, 2007, 10:33:17 AM »
Sheepdog, we really need a big, slobbering drool smiley.
Rob, how does the powerband come out?  Within the bounds of the secret-sauce confidentiality, what can you tell me about boost lag and peakiness of the power.
« Reply #20 on: August 08, 2007, 12:50:35 PM »
Quote from: bmwman91;31225
yes i'm quite interested to hear about this as well.
i see it is a front mount intercooler...did you have to cut out the bumper support or did you manage to fit in there?
rob_e30
« Reply #21 on: August 08, 2007, 03:35:12 PM »
I did cut out sone of the bumper support and trimmed the mouth of the new bumper cover.
Here are some more pics
nickmpower
« Reply #22 on: August 08, 2007, 08:22:10 PM »
hey rob, how many miles on the engine? have you done a leak down or compression test? Im having troubles with my rebuilt engine and another new engines compression or leakdown results would really help out
rob_e30
« Reply #23 on: August 08, 2007, 09:20:01 PM »
Zero miles since a complete rebuild.  Replaced the crank and using custom pistons.  CR is 8.5:1 so I'm not sure what my numbers would do for you by comparison.  I also have not done either test.
The leakdown is pretty straight forward...  What is the % leaking?
On the compression test, as long as you get a close reading on the same number of cranks with all of the plugs removed you should be in good shape.
nickmpower
« Reply #24 on: August 08, 2007, 09:45:31 PM »
I have about 20-30% leakdown. along with about 130-140 compression. And TONS of blowby. so much that the engine leaks from all the crankcase pressure. About 10 miles on the car
rob_e30
« Reply #25 on: August 09, 2007, 08:40:29 AM »
30% is starting to get to the high side.  Is the leak down the same on all cylinders?  Are you careful to make sure you're at TDC?  If you are at TDC if you rotate the crank a little back and forth slowly does it change the reading?  Rotating the crank will start to open the intake or exhaust valve and hear the air coming from the intake or exhaust manifold.
But, given that it's pressurizing the crank case I would suspect rings.  If it's the same for every cylinder then either the rings or pistons are not the correct size.
nickmpower
« Reply #26 on: August 09, 2007, 11:31:50 AM »
i think the machinist just didnt install them properly, but it could still be that they need to be broken in which is why i was wondering if you had tested it. What pistons do you have? ive got JE. if theres anyway you could do a leakdown that would help me a lot
Its hard to rotate the crank around TDC because it just turns over. all the air is going past the rings.
rob_e30
« Reply #27 on: August 09, 2007, 02:19:08 PM »
I won't get a chance before we head to the track this weekend, but I've not heard of rings needing to be broken in to solve your problem.  Have you talked to your machine shop?
I'll try and get one done for you early next week.
nickmpower
« Reply #28 on: August 09, 2007, 03:30:04 PM »
The machinist said it probably needs to be broken in more but im thinking hes just praying it some how fixes itself. Ive had so many problems with this engine before and now after the rebuild it makes me sick
if theres any way you can test just one cylinder before you head out to the track that would be great. It seems like after the mileage differences may be too great to make any sort of comparison
Bunta
« Reply #29 on: August 09, 2007, 06:08:47 PM »
I love this picture
Get them started early.  How many of us wish our dads were like this?
Cool project.  No love for the looks of the car but its really about what works.
Hunter
