Author Topic: Can some experts please examine this car for sale?  (Read 2748 times)
Snarcher
« on: February 03, 2007, 06:55:16 AM »
1992 Green 318i Convertible 192k miles 5speed
worth 3500??
Date            Miles   Work
3/21/99         125666  purchased by 2nd owner
4/1/99          125782  repl. top header seal
10/7/99         129307  LOF, wiper blades, 2 tires, flush brake fluid & coolant, alignment
11/3/99         129939  new rear defog. fan
12/17/99                front grill
12/24/99        131458  checked for stalling
12/30/99        131631  LOF, cool. temp. sens., air filter, valve cover gskt., plugs, fuel filter, coolant flush
1/19/00         132101  checked for stalling
1/26/00         132223  throttle cable, inst. clstr. bulbs
4/1/00          134977  LOF, wiper blades, wheel roundels
8/30/00         140407  rear exhaust/muffler, wiper blades
12/07/00        143337  LOF, timing chain/rails/tensioners/case, head gasket, oil pan gasket
4/3/01          147075  LF window switch
4/5/01                  top front seal
4/13/01         147345  LOF, right side gasket
4/14/01                 rear speakers
4/23/01         147680  2 tires
6/5/01          149298  2 tires, alignment
6/11/01         149454  reseal timing cover
7/30/01         151473  front & rear pads/rotors/sensors
9/4/01          153248  LOF
10/12/01        154431  clutch kit, u-joint
6/6/02          158917  LOF
7/30/02         161143  rear shock mounts, hood roundel
8/6/02          161417  driver's door lock
8/8/02          161493  3 engine belts
8/26/02                 new alarm
9/5/02                  new antennae
10/17/02                new top, repair upholstery
10/18/02                car cover
5/3/03          164244  LOF
5/20/03         165082  rotate & balance
7/22/04         173629  LOF
9/16/04                 2 tires
11/19/04        180243  LOF, front pads/rotors
sheepdog
  • Site Admin
« Reply #1 on: February 03, 2007, 02:22:47 PM »
What is the condition of it in?
Verts' get good money, so if it is nice, then yes, it is probably worth it.
I would drop the lower pan the moment you get it home with that mileage to check all of the bolts..
And keep in mind, a 318 vert', will be sluggish.
« Reply #2 on: February 03, 2007, 03:57:05 PM »
Pics? Where is it? Has nothing been done in 2+ years?
Snarcher
« Reply #3 on: February 04, 2007, 10:06:58 PM »
its pretty much mint condition, only problem is that its that teal color that i hate.. argh!
Choking Hazard
« Reply #4 on: February 05, 2007, 09:06:38 AM »
All dealer maintained, eh?  Thats gotta be rare...
[SIGPIC][/SIGPIC]-Scott
« Reply #5 on: February 05, 2007, 10:02:25 AM »
Quote from: Snarcher;18822
getting another vert huh??
welcome to the forum btw!
