Author Topic: Pic id needed/request  (Read 2964 times)
Froos
« on: May 22, 2016, 10:49:10 AM »
Hi all, can someone provide pic id for the following numbers please?
12,14 and 19 please, i suspect my engine came with some parts missing
1. Fuel tank with pump
2. Liquid/vapor separator
3. Fuel filter
4. M1.7 control unit
5. Ignition coils
6. Spark plugs
7. Injectors
8. Fuel rail
9. Fuel pressure regulator
10. Coolant temperature sensor
11. Throttle valve potentiometer
12. Idle control valve
13. Active carbon canister
14. Evap. purge valve
15. Airflow meter
16. Air temperature sensor
17. TDC and RPM sensor
18. O2 sensor
19. Cylinder identification sensor
20. Battery
21. Ignition switch
22. Main relay
23. Fuel pump relay
Froos
Re: Pic id needed/request
« Reply #1 on: May 22, 2016, 03:21:37 PM »
Also with my itb build is there really a need for the icv? Will the engine start if i just delete it? Sure idle will be a pita but will it run or will the ecu prevent the engine from running?
Froos
« Reply #2 on: May 23, 2016, 01:42:31 AM »
19 is just the cam sensor...
DanOKC
« Reply #3 on: May 25, 2016, 01:51:06 AM »
Here you go.
ICV mounts at back side of intake manifold, near the firewall.
Evap purge valve has about 3 to 4" of hose connecting to the charcoal cannister & has 1 electrical plug & another hose going somewhere. I'm not sure it is actually mounted, think
it just is supported by hoses, but I could be wrong, maybe a clip is holding a hose & supposed to be there ?
