Author Topic: minimum wiring to run e36 m42 with 990 dme  (Read 2970 times)
m42240z
« on: April 30, 2016, 09:43:06 PM »
i have an m42 in my datsun and started the wiring. i have 12v from ign to dme (via relay) through the x20 main harness. grouns are secured and main/fuel pump relays are getting voltage to pin 30 but fuel pump will not prime when ignition is switched on. any ideas?
Delta
Re: minimum wiring to run e36 m42 with 990 dme
« Reply #1 on: May 03, 2016, 03:49:30 PM »
In the e30 the fuel pump does not prime until the motor is cranking. If you have it wired the same way then it will not prime with the ignition on.
