DISCUSSION
Swaps, Turbos, Buildups
Another M44 stroker Build 90mm Crank Question
Pages:
3
Topic: Another M44 stroker Build 90mm Crank Question (Read 25208 times)
mt500ish
Freshly Registered!
Re: Another M44 stroker Build 90mm Crank Question
Reply #30 on:
April 17, 2016, 09:26:29 AM »
Hi Ralph
Thanks for your reply.
The builder phoned me and said about CR before decking the block and said 13:1 CR will print your reply and show him.
The bigger HG could be a winner
Have m42 head with 6mm valves and solid lifts so will do the maths to find the answer will know more tomorrow.
Thanks again
Warsteiner
Hero Member
-Receive: 21
Reply #31 on:
April 17, 2016, 04:51:44 PM »
mt500ish,
Ok well if it was 13:1 before you decked the block then it is even higher now!
You had really better do your math a few times to get it right and be sure that everything is correct.
Good Luck..
Cheers,
~Ralph
KILL3R
Freshly Registered!
Reply #32 on:
July 31, 2018, 05:50:33 AM »
mt500ish
, have you finished working on your stroker?
I was folowing this topic, hoping you will confirm us your success
Is it working ok? Any dyno charts?
mt500ish
Freshly Registered!
Reply #33 on:
July 31, 2018, 12:14:10 PM »
I still have the engine in the end the pistons sit about 0-5 mm below the block the engine was put together so need to strip it and deck the block
I have not touched the engine for a long time as am still building the car here is a couple of pictures with this m44 engine installed when the car is done then will put stroker in the car, still sorting rear axle.
I have had the car 8 years now 2 children later say no more
JXD
(OO=[][]=OO) 318iC 1991
Reply #34 on:
January 30, 2020, 06:40:03 AM »
Quote from: mt500ish on April 16, 2016, 04:45:05 PM
Been to collect the crank today and it had a bit of a design change
How is the extension fixed to the crank ?
Pages:
3
DISCUSSION
