Author Topic: m42 KOMPRESOR!!!! UPDATE!!  (Read 12481 times)
SkidMark
  • ex pro bmw wrench.. 15 yrs bavarian auto haus
  • OO==[I]==OO
Re: m42 KOMPRESOR!!!!
« Reply #15 on: November 11, 2014, 03:18:27 PM »
It is a stock e30 lower intake manifold.... skid
1970 BMW 2002, 1988 BMW 325ix, 1979 BMW 320i m42 powered race car, 1969 BMW r75 cafe bike, Greasy fingers, Empty bank acct, Pissed off wife, Unhappy dog, Filthy garage.
Arthur
  • Le Mans Driver
« Reply #16 on: November 12, 2014, 10:52:46 AM »
SkidMark
  • OO==[I]==OO
« Reply #17 on: December 23, 2014, 11:41:12 PM »
Well i figured I would give you all an update.. The car runs fantastic with the mercedes eaton supercharger!!! I got together with Jake from classic daily, best guy ever!!, and we decided to change DME's to a e30 from a e36. This enabled me to run his turbo tune for the m42. He scaled back his tune as I am running less boost and smaller injectors. The car runs great, idles perfect, and pulls HARD!! Its running about 7 psi boost at 6500 rpms, and is a solid 14.7 afm. Havent gotten it on the dyno yet but its really really fast!!!!  THANKS JAKE!!! You da Man!!!  Skid
Darky
  • -Receive: 23
Re: m42 KOMPRESOR!!!! UPDATE!!
« Reply #18 on: December 24, 2014, 05:34:11 AM »
Hi Skid
Why did you change the dme, to e30 from e36? Disa
Cheers Rohan
SkidMark
  • OO==[I]==OO
« Reply #19 on: December 24, 2014, 06:58:46 AM »
Hi darky! Since I had to build a new manifold there is no disa valve. Also, i couldnt find anyone that had a tune or could write a tune suitable for boost applications in an e36 chip. Would have loved to use an e36 dme because of its knock detection but it just didnt work out. I guess the e36 is a completeley different animal when it comes to writing tunes. I am not a tuner by any means thats why I called Jake B. ... Skid
Darky
  • -Receive: 23
« Reply #20 on: December 24, 2014, 04:21:23 PM »
Hi Skid
I just thought that the disa in the e36 programming would be the pain.
That makes sense with regards to keeping knock sensors. I can't understand why e36 dme is that much harder to program. What's does 14:7 afm mean?
Be interesting to see your dyno curve and your air fuel ratio curve.
Cheers Rohan
SkidMark
  • OO==[I]==OO
« Reply #21 on: December 24, 2014, 04:51:43 PM »
14.7 afm, the air to fuel ratio.
colin86325
« Reply #22 on: December 25, 2014, 11:37:05 AM »
I hope the 14.7 refers to idle AFR only. That's far too lean for higher rpms/loads
SkidMark
  • OO==[I]==OO
« Reply #23 on: December 25, 2014, 11:43:27 AM »
Yea Collin thats at idle. Its around 9.8 to 10.2 w.o.t. ..thats a little richer than I would like but ok for today. Jake burned me a leaner chip I havent tried yet but I will give it a shot possible today....Skid
AdOz
« Reply #24 on: January 30, 2015, 03:10:56 PM »
Wow! Very interesting!
I'm currently building a setup from a merc (m62) onto and m42 for my e10.
I really didn't think standard ecu would even be an option I've been looking at standalone!
Do you have any photos of your pulley set up? And sizes? And belt tensioning?
Are you planning to get it on the rollers soon? I'm not sure what sort of injectors to use yet also!
Also the bypass system? Have you used it or are you just running it under boost constantly? I've gone for a different set up with the manifold as I'm wanting to run an intercooler going I to a plenum as I was worried about tempratures
« Last Edit: January 30, 2015, 03:12:39 PM by AdOz »
