Author Topic: ITB and ALPHA/n CONTROL UNIT SETUP INFO  (Read 4171 times)
CraigW
« on: September 27, 2014, 06:06:56 PM »
Just had all new complete itb set up (with Dbilas ecu chip), alpha/n control unit and flow master air box shipped from Dbilas in Germany ... looking for knowledge on set up, running and tuning, or any information at all would be much appreciated ... street use ... didn't change cams or anything else.
Also need to know
1.  Where on the idle control valve is supposed to point, towards the plenum or the itb's?; and,
2.  How do you adjust the two set screws on the throttle linkages?
Thank you, Craig
1992 e30 m42, 5 lug conversion,
all m3 e30 underpinnings,
billstein shocks, H&R springs, cabriolet
