Author Topic: help install zf m3 trans (not lined up right)  (Read 7255 times)
Burt_318iS
Re: help install zf m3 trans (not lined up right)
« Reply #15 on: August 22, 2013, 08:26:05 PM »
The drive shaft will come later... im finishing up the intake/fuel/intercooler duct work first. And then Im going to measure my gap between the shaft and diff and have a shop lengthen it
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #16 on: August 22, 2013, 10:34:43 PM »
If the front section of the driveshaft is the same length you are in luck. If you loosen the nut on the rear section right behind the CSB the driveshaft is "adjustable."
-Nick
91 E30 M42 with VEMS
