Author Topic: M44 into M42  (Read 4255 times)
1991 E30 M42
M44 into M42
« on: January 03, 2007, 09:36:36 PM »
I have M44 .50 over pistons, connecting rods, and crank shaft than I want to put into an M42 block, but I dont know if it would work. Has anyone ever done this? Im pretty sure it should work, but I think the M44 has a longer stroke.
2002maniac
M44 into M42
« Reply #1 on: January 03, 2007, 11:00:04 PM »
Quote from: 1991 E30 M42;16729
yes that will work just fine and make decent power as well.
1991 E30 M42
M44 into M42
« Reply #2 on: January 03, 2007, 11:13:38 PM »
Thats what im hoping considering it takes the engine to almost 2.1 liters plus I'm gonig with a custom intake manifold, Apex'i AFC controller, adjustable FPR, Fidenza flywheel, and S52 Clutch
M44 into M42
« Reply #3 on: January 04, 2007, 01:21:53 AM »
What is the displacement of the M44 and the 2.1 liter configuration. They are both in the E36 318is. What are the bores and strokes involved? I thought the M44 was simply OBDII.
1991 E30 M42
M44 into M42
« Reply #4 on: January 04, 2007, 07:11:26 AM »
The M44 from factory has a 1mm larger bore than the M42
