Author Topic: New problem after fixing my hesitation  (Read 8149 times)
91 318i
« Reply #15 on: May 08, 2013, 06:43:30 PM »
Still waiting on the o2 to come in but in the mean time I found a spare icv that I cleaned and swapped in. What's odd is its a different part number but the same part. It's a straight through Bosch icv with a 2 wire plug. Identical to the one I had originally just a different part number. Both are Bosch. Both look the same.
Anyways. We'll see what happens with this quick little swap out. I also wrapped any possible vacuum leak suspect entirely with electrical tape. Which looks extremely ghetto but its easier than finding a replacement part for a quick test.
1991 BMW 318i Sedan
1995 Ford F150 4x4
91 318i
« Reply #16 on: May 14, 2013, 08:10:11 PM »
New o2 sensor in. Still have a check engine light. Took apart the intake manifolds and siliconed between all mating/gas keying surfaces to ensure no chance of a leak. Still check engine light.
While I had the intake apart I noticed oil residue from the PVC hose in my intake. It was in the manifolds and the rubber intake hose and a little in the afm. I'm currently running 10w 30 synthetic. I know the factory recommends 15w 50 synthetic. Will that cause a rich/lean check engine light?
Another question is whether or not a messed up exhaust manifold gasket could cause this. I know when I was installing the motor i got one of the gaskets stuck and it got terribly bent up. I ordered new gaskets for that already but was wondering if a leak there would cause this light.
1991 BMW 318i Sedan
1995 Ford F150 4x4
colin86325
Re: New problem after fixing my hesitation
« Reply #17 on: May 15, 2013, 07:35:39 AM »
That oil should be fine.  I use 5w30 in winter and 10w30 in summer.  A bit of oil residue in the throttle body is normal, though I haven't seen it in the AFM.  I suppose it accumulated and ran downhill.
A leaky exhaust gasket (or hole in your exhaust, upstream of sensor) can fool your O2 sensor and might trigger an error code.
91 318i
« Reply #18 on: May 15, 2013, 10:25:56 PM »
Okay. If this doesn't work I'm just gonna block the opening so I don't see the light anymore
1991 BMW 318i Sedan
1995 Ford F150 4x4
91 318i
« Reply #19 on: May 18, 2013, 12:20:50 PM »
Manifold gasket didn't resolve it but at least have no more leak and my #1 exhaust port isn't blocked off about a quarter of the way
1991 BMW 318i Sedan
1995 Ford F150 4x4
91 318i
« Reply #20 on: May 18, 2013, 12:44:29 PM »
1991 BMW 318i Sedan
1995 Ford F150 4x4
