Author Topic: M42 Engine faults Cutting out at 4500 RPMs  (Read 13614 times)
Broach318
« Reply #30 on: March 07, 2013, 04:35:52 PM »
http://www.youtube.com/watch?v=NcaD2oRjb4s
So this is odd, car is running and has 0 PSI... anybody? Im stumped, only thing I can think of is stuck open fuel injector. Exhaust is strong and squirts out fuel..
Broach318
« Reply #31 on: March 07, 2013, 04:37:22 PM »
« Reply #32 on: March 07, 2013, 04:43:19 PM »
Hmm.  Never tested a relay for resistance before.  I'd suspect the switch side (85& 86) would be a pretty small resistance, but the load side would be infinite, at least for a standard always-off SPST version.
The FPR does vary the fuel pressure based on intake vacuum - but your problem seems like a flow issue.  That pump seems a bit weak regardless...IIRC 43.5psi (3bar) is minimum system pressure for the M42.
Put a hose on the fuel pump and run it to a gas can.  With the key on and the fuel relay socket jumped (or 12VDC on the fuel pump terminals), Bentley says you should see nearly a quart every 30 seconds.  That's be a gallon every 2 minutes.  With this test you can eliminate the entire supply system and isolate the fuel pump for testing.
If this test succeeds, then maybe a blockage in the system?  Crimped fuel supply or return hard  line, internally collapsed hose, blocked filter, plugged pump sock, something like that?
Broach318
« Reply #33 on: March 07, 2013, 09:32:41 PM »
AHHH, Finally its FIXED!! It was the power connector to the fuel pump was busted, so it would not stay on the prongs. The "fuel cut" i was experiencing was the connector going from making contact to not and would kill the pump and come back on. Wow am I glad thats fixed now to find a new plug somewhere. Thanks to everyone for the input!!
Broach318
« Reply #34 on: March 08, 2013, 08:08:51 AM »
 Here is the plug.
