Author Topic: E30-E36 Chamshaft position SENSOR problem??  (Read 7071 times)
ReSuL
E30-E36 Chamshaft position problem??
« Reply #15 on: February 12, 2013, 01:11:04 AM »
I have an AFR and it says 14,6 most of the time..
How can I be sure about the failing coil driver in the DME??
romkasponka
« Reply #16 on: February 12, 2013, 01:19:06 AM »
Failing coil driver would give you rich because in one cylinder fuel would not be burned.
E30 318is M42
E36 318is M44
Nelson_40
« Reply #17 on: February 12, 2013, 03:08:38 PM »
Quote from: romkasponka;120031
Duh on my end saying lean running due to coil issues, you are quite correct that would cause rich running. I still think an examination of the plugs will yield the some useful information.
keflaman
  • -Receive: 35
« Reply #18 on: February 12, 2013, 07:43:41 PM »
Quote from: ReSuL;120030
I was getting fault code 1271 "#1 coil" on the stomp test (and IIRC, 55 on my scanner). Swapping in different coils didn't do anything, but it went away when I swapped in a different DME.
romkasponka
« Reply #19 on: February 12, 2013, 11:46:25 PM »
Quote from: keflaman;120056
Once I had failed coil driver in DME but it was not firing at all. My friend replaced them, but probably newer transistors are faster so ignition timing was off, but it worked at that moment. Later I just bought other DME. And the problem why coil driver failed was because ignition coil was failed. So bad ignition coils burns your DME!
E30 318is M42
E36 318is M44
keflaman
  • -Receive: 35
« Reply #20 on: February 13, 2013, 12:09:51 AM »
Quote from: romkasponka;120060
I faintly remembered reading that once, so my test was conducted very quickly!:eek:
After removing the plastic cover and inspecting them closer I could see the laminated steel core was de-laminated and bulging where rust had started between the layers. Maybe I should take a few pictures to show what I mean?
romkasponka
« Reply #21 on: February 13, 2013, 01:19:41 AM »
Quote from: keflaman;120061
In my case there was a crack on plastic body.
E30 318is M42
E36 318is M44
ReSuL
« Reply #22 on: February 13, 2013, 02:12:59 AM »
I have ignition fires all the staff with no code on DME.. but I am suspicious of the timing because of CPS that is why I tried the replace CPS.. and the question is lets remember :D does E36 CPS work on E30??
ReSuL
« Reply #23 on: February 18, 2013, 12:27:47 AM »
Here is the answer... NO! it seems nothing changes but in a few days the injector's timing changed from 3,40 to 1,92 which made the fuel consumption worse with no power gain...
so I put the old one on but I am sure it doesnt work...
