Author Topic: M42 start issues. Starter not always turning  (Read 10063 times)
Geoff
« Reply #15 on: November 09, 2012, 06:32:41 PM »
It really looks like the same thing to me..what up,  Romkasponka?  I mean not the same but will have the same effect.
        Geoff
romkasponka
« Reply #16 on: November 10, 2012, 04:33:05 AM »
Bendix
Quote
Will not grounding the lower nut be the same as grounding the starter chassis as it is all metal?
Correct.
Quote
hmm interesting. Do you mean that the starter relay is in the bendix drive?
Yes and no. Lets say it is contactor for high A and it engages starter motor with flywheel.
Quote
How does the M42 starter terminals actually work?
I mean, what do the do?
I drooped you a link there is good explanation. Big terminals inside bendix are shorted then you crank engine. Small terminals are to energize contactor and engage starter with flywheel.
« Last Edit: November 10, 2012, 04:43:34 AM by romkasponka »
E30 318is M42
E36 318is M44
romkasponka
« Reply #17 on: November 10, 2012, 04:46:12 AM »
Quote from: Geoff;117530
        Geoff
It wil not have the same effect. You will weld something because will make Short circuit when you energize bendix if you will try to do it like in maximan picture ;)
E30 318is M42
E36 318is M44
maximan
« Reply #18 on: November 10, 2012, 06:34:01 AM »
Very nice explenation!
I begin to think that the bendix drive is the sinner here.
But i there was one thing i didnt understand.
You mean the current passes through the leader in the bendix drive and then through the unisolated cable into the stator and then to ground?
It seems it is no easy solution here other than replacing the starter motor again:(
romkasponka
« Reply #19 on: November 10, 2012, 07:04:27 AM »
Quote from: maximan;117537
Yes.
E30 318is M42
E36 318is M44
Geoff
« Reply #20 on: November 10, 2012, 07:17:53 AM »
thats a good explanation.  now I even understand it:rolleyes:
maximan
« Reply #21 on: November 10, 2012, 08:12:51 AM »
OK :D Glad we have it all sorted out!
It seems that i will have to replace the starter/bendix. Not what i hoped for but thats it.
It seems the problem is found, but the thread will be open in case i need more help or other have similar problems.
Thanks a bunch you guys!
