dome light
Author Topic: dome light  (Read 3763 times)
Meister
dome light
« on: November 24, 2006, 08:57:48 AM »
When I open my driver side door, my dome light will not turn on, but it will if the passenger side door opens.  So my question is, where do I need to look to fix this?
individualist
dome light
« Reply #1 on: November 24, 2006, 10:09:50 AM »
Check the button inside the door jamb, down where the door is hinged. Check to be sure the button is not stuck, you should be able to push it in and when released, it will pop back out.
Meister
dome light
« Reply #2 on: November 24, 2006, 05:06:04 PM »
Thanks, I found the button.
It wasn't stuck all the way in but for some reason, I still have to pull the end everytime i push the button in, in order for the light to turn on.  Should I maybe spray some wd-40 on it?
dome light
« Reply #3 on: November 24, 2006, 05:19:45 PM »
nope...theres a switch on the dome light!
Meister
dome light
« Reply #4 on: November 26, 2006, 01:48:46 AM »
I know theres a switch lol i just like my light to turn on when i open my door, becuase my light on the other side is broken (not just the bulb)
dome light
« Reply #5 on: November 26, 2006, 11:58:05 AM »
my switches are wearing out and it takes a few sec's on the DS for the lights to turn on and I have to pull the switch out on the PS for the lights to come on :(
dome light
« Reply #6 on: November 26, 2006, 12:53:38 PM »
Quote from: Meister;14456
yes, thats what the switch does. there are two positions, one for always off, the other for when you open the door the light turns on.
Meister
dome light
« Reply #7 on: November 26, 2006, 03:40:29 PM »
i know that lol
dome light
« Reply #8 on: November 26, 2006, 05:19:30 PM »
You could swap driver and passenger door switches and then grab one next time you go to a salvage yard.
shellback
dome light
« Reply #9 on: November 26, 2006, 07:01:55 PM »
or you could always enter and egress from the PS...
Choking Hazard
dome light
« Reply #10 on: December 03, 2006, 10:08:36 PM »
Yes.
WD-40
[SIGPIC][/SIGPIC]-Scott
