Author Topic: Timing help - Turned crank without chain...  (Read 6432 times)
doitover
« Reply #15 on: July 27, 2012, 09:57:19 AM »
Sample size one. Mine moved a little but not enough to really think about. The center of the movement was pretty obvious from what I remember.
Quote from: alim_h;113962
I borrowed the cam locking tool for a BMW mechanic in town.
I used an M8 bolt for the flywheel lock but noticed even with the lock in place the crank still moves. I measured the movement and it's about one tooth on the harmonic damper. The harmonic damper has 60 teeth so each tooth is 6 degrees.
I thought that was a lot, but then counted the teeth on the crankshaft sprocket. There are 18 teeth so each tooth is 20 degrees. That means the movement isn't enough to skip a tooth on the crank sprocket. So I should be ok right?
Does everyone have movement when the crank is locked to the flywheel?
« Reply #16 on: July 27, 2012, 11:33:42 AM »
It sounds like you should be able to get everything together properly. If you decide to double-check by looking for 81mm marks on a rod, be sure to be consistent in how the marker is positioned and where on the piston the rod hits or you will have a hard time getting things together properly. I usually take a Sharpie and lay it on the flat surfaces at the top of the plug holes to get a consistent pen position.
alim_h
« Reply #17 on: July 27, 2012, 11:50:40 AM »
I did a compression test... All the cylinders are 120+ except cylinder 1 (<30). What a shitty feeling.
On to replace some valves...
« Reply #18 on: July 27, 2012, 12:30:01 PM »
Yikes. You sure you hooked the gauge up properly?
doitover
« Reply #19 on: July 27, 2012, 01:14:24 PM »
Definitely read around on doing compression checks correctly. I know I was getting pretty inconsistent results until I saw someone suggest putting a couple of drops of oil in the cylinder. That and have the throttle wide open.
alim_h
« Reply #20 on: July 27, 2012, 02:48:57 PM »
Yeah the other cylinders are reading with good numbers - bent valve? I started tearing into the head. I'll keep you guys updated.
Thanks for the tips!
