Author Topic: Wheel Studs  (Read 6578 times)
oldtimer
Wheel Studs
« Reply #15 on: May 20, 2007, 09:43:36 PM »
Probably off topic here.  Since the talk of replacing the OEM lug bolts with studs am I to assume that you guys are running with spacers both front and rear.  If so what thickness are you using for the rear and the front?
I am thinking of doing the same and run spacer like I do on my Boxster S.  Thicker on the rear 17mm, any thoughts on this?
Wheel Studs
« Reply #16 on: May 21, 2007, 12:55:01 AM »
great thread.
i might be picking up that 60mm stud kit.
