I've had a problem with my rear brakes sticking on.
Is it possible to replace the rear inner flex lines without dropping the rear
crossmember?
I replaced the calipers, which worked for about a month and then siezed to the point of melting the rubber seals on the caliper. I then replaced those calipers,
the master cylinder and the outer flex lines. It hasn't locked since then but after about a week of driving and can feel them dragging. That is how it began before they locked up the last time so I suspect I didn't solve the problem.
From what I've read, the next thing to do is to replace the inner flex lines. At that point most people replace all of the hard lines and drop the rear suspension to do it. It looks like the hard lines on mine are in good shape.
Thanks,
