Author Topic: m42 tuning  (Read 16860 times)
bmwconnect
m42 tuning
« Reply #15 on: February 06, 2012, 03:55:58 PM »
Quote from: Esprit Aviation;110041
WOT AFR is consistently 11.5:1 to 12.0:1 at 5psi,  2500 to 6000 RPM; verified by my son during the track sessions.
Is there any other open loop mode that we really care about other than WOT?
It's before that turbo spools is where tuning plays a big part. No tuning = slow spool times, overly rich conditions, and in worst cases you compress the fuel.
Yes there is start up open loop enrichment based on coolant temp witch will foul plugs when you toss in bigger injectors.
People will still continue to believe they can just swap in different injectors without software, without understanding the consequences.
oh well
Midnight YouTube Channel
Esprit Aviation
m42 tuning
« Reply #16 on: February 06, 2012, 04:29:56 PM »
We get 5psi @ approx. 2500RPM and typically don't shift at less than 2500. I am well aware of when open loop occurs. Plugs are clean, never a start failure in 20k mi. of driving including winter 2010-2011 in Upstate NY.
We understand the consequenses. In 20k mi. with this set-up there are none; and that's acceptable to us.
hondo898
m42 tuning
« Reply #17 on: February 07, 2012, 08:33:40 AM »
I should be able to run a t3 turbo with no issues also as long as I use the Injectors from the 900. If I'm thinking correctly
Esprit Aviation
m42 tuning
« Reply #18 on: February 07, 2012, 02:13:18 PM »
You should be able to run the t3 ok. It is a bit larger and will have a bit more lag; however they are easier to find and they have the same flanges. You will easily keep the t3 within a very efficient area of the map. Later on if you significantly increase boost you will most likely remain efficient.
T3 equipped cars may have had slightly different injectors. I am not certain.
hondo898
m42 tuning
« Reply #19 on: February 07, 2012, 08:07:15 PM »
I currently have a few saab mechanics that I know keep an eye out for a te05-12b turbo. Worst case ill grab a t3 or something comparable. You have been a great help, I appreciate it!
Esprit Aviation
m42 tuning
« Reply #20 on: April 01, 2012, 06:06:18 PM »
Bump for update! Did you locate a turbo?
BeemerDan
Re: m42 tuning
« Reply #21 on: March 24, 2014, 06:18:35 PM »
I realize this is an old thread, but how many hp was the car running with 5psi? And is it still working fine?
Thanks!
Dan
