that valvetrain setup i HOT! all from catcams eh? im guessing its all custom correct? do they have ready made kits for cam upgrades?
Catcams: YES
They should be able to provide you with what you want!
They didn't have specific measurements for the cylinderhead when i first talked to them. So i sent them mine, and they were kind enough to measure everything out for me.
But be warned, allthough it's all measured out dosent mean it's just plug'n'play. You will have to check EVERYTHING, i found that i will have to grind ~0,5mm off the top of the valve collets. To provide the shim-collet clearance nessasary (0,4mm). The shim was sitting on the collet.
You could come up with other solutions to the problem, but i found this to be the easyist. And most straight forward. I've seen Schrick valves with only one groove, so i think i'll be okay with 2½ groove.
Where dit all my money go.. :-(
BTW: I have plans on drawing up some valve lift curves on both standard cams and the rally cams. for comparison. I could post the curves in near future if theres interest
