Author Topic: O2 sensor question  (Read 7173 times)
mwilderl
O2 sensor question
« Reply #15 on: June 11, 2011, 12:14:18 AM »
Might be setting up a turbo on there, i have a log manifold, turbo and intercooler along with some piping. NOt sure what the benifits of having a WB O2 is though.
Nelson_40
O2 sensor question
« Reply #16 on: June 12, 2011, 09:21:29 PM »
Quote from: mwilderl;104495
In my understanding a narrow band sensor, i.e. regular O2 sensor, will operate more like and on/off switch in terms of detecting lean/rich operation.  Whereas a wide band sensor will provide ECU inputs more akin to the operation of a rheostat, allowing more precise fuel metering and thus better power delivery.  The benefit is that in turbo/supercharged settings you get safe metering of fuel without risking detonation, not to mention that the engine should not run as rich the way some poorly tuned cars run.  If this isn't accurate I hope someone else will chime in.
Bl0mgren
O2 sensor question
« Reply #17 on: June 13, 2011, 11:26:38 AM »
original ecu need narrow band signal input.
http://www.autometer.com/tech_faq_answer.aspx?sid=1&qid=48
Nelson_40
O2 sensor question
« Reply #18 on: June 13, 2011, 04:07:35 PM »
Quote from: Bl0mgren;104537
There are some wide band to narrow band converters available for this task, but I do not know if our Motronic will work well with them.  Any one else have a wide band sensor with a stock ECU that can enlighten everyone?
O2 sensor question
« Reply #19 on: June 13, 2011, 06:44:57 PM »
The basic description of narrow-band sensor output is that they are only accurate for exhaust gas mixtures from a stoichiometric burn (~14.7:1 A/F). In rich & lean conditions, there isn't a good way to pull exact A/F ratios because the exhaust gas temperature is not accounted for, which makes a difference. Hence, they can only be accurate for a very narrow range of A/F ratios. Wide-band sensors do account for temperature, allowing them to accurately read a wider range of A/F ratios.
mwilderl
O2 sensor question
« Reply #20 on: June 14, 2011, 01:34:17 PM »
so it sounds like i need to get a NB sensor until i decide i should go to a standalone ecu?
O2 sensor question
« Reply #21 on: June 14, 2011, 02:42:11 PM »
For the most part, yes. A WBO2 system really doesn't do anything for you with the stock ECU, unless you are trying to rig up a forced induction system with the stock ECU and larger injectors.
mwilderl
O2 sensor question
« Reply #22 on: June 14, 2011, 09:00:21 PM »
Might happen at some point in the next year ;) but we all know how long these things really take... I might just go all out when i do turbo and go to a standalone.
Bl0mgren
O2 sensor question
« Reply #23 on: June 19, 2011, 09:23:01 AM »
Quote from: Nelson_40;104543
I have Innovate LC1 for this task, works good.
Bl0mgren
O2 sensor question
« Reply #24 on: June 21, 2011, 03:46:09 PM »
found a interesting thread.. right or wrong?
http://forums.bimmerforums.com/forum/showthread.php?t=788400
