Let me describe now,
1/2. didnt drain coolant (should I? then re pour it in with the bleeder screw removed)
1. I used the bleeder valve while it was running to get any built up air out got a little bit of bubbles
2. put more radiator fluid in up to the line on my resivor.
3. when i thought it was good drove car.
4. car still overheats.
4 1/2. all three hoses are hot to the touch...
5. heater fans do not work, cant tell if there is heat in the heater.
6. need to work tommarow.
7. called off today because of car.
8. depression sets in
