Getrag 240 Torque Limit Found
Author Topic: Getrag 240 Torque Limit Found  (Read 22617 times)
rob_e30
« Reply #15 on: April 11, 2011, 08:22:45 AM »
Quote from: jscribble;102483
Bummer man. Any tricks needed for the e36 trans to fit/bolt up?
We have the transmission bolted up, but need to resolve the throw out bearing and prop shaft.  The ZF has a different output flange so we need to find the proper length prop shaft.  We're probably going to have our existing prop shaft customized.  We'll shorten it by 2" and have the flang from the E36 welded on.
NisseJärnet
« Reply #16 on: April 20, 2011, 06:50:19 PM »
Quote from: rob_e30;102957
Try to find a 328 E36 shaft, they usually fit bolt on with the ZF tranny :)
-88 E30 325i M50 6spd turbo, 764whp
-89 E30 318i M42, 140hp COP conv. (E36 engine + gearbox, 3.73 188 diff)
-90 E30 318is M42 turbo, 240whp (sold)
http://www.youtube.com/nissejarnet
E30PQ
« Reply #17 on: April 20, 2011, 07:12:18 PM »
We run the M20 flywheel and clutch off this M42 turbo.  We just added the E36 5 speed ZF trans.  Does anyone know what TOB would work?  We tried the G260 TOB and that didn't work.  We have a 323 TOB but we haven't tried that yet.
Any ideas which TOB will work with our combination?
wanganstyle
« Reply #18 on: April 21, 2011, 10:09:27 PM »
are you running the 228mm clutch and flywheel set? single or dual mass? the dual mass entire setup from g260 e30 is = the g250 e36pn which is = stack height as s52's 240mm dual mass setup for ZF SG320
the S52 uses a dual mass setup stock, have you tried using that or at least comparing the original S52 clutch with the setup you are trying to run?
OEM sachs S52 clutch holds more than 350rwhp, so you could just run the stock item.
left is a E24 633CSi single mass flywheel setup in 240mm (OEM BMW)
right is UUC stage 2 single mass flywheel setup  for S52 e36m with zf trans with Sachs e34m5 clutch+pp+friction disc
I would use whatever TOB is used in the E34M5 clutch kit
DaveM-sport
« Reply #19 on: August 05, 2011, 05:45:20 PM »
Quote from: E30PQ;103234
323i throw-out bearing will work perfectly with an M20 lightened flywheel and clutch.
I used that setup with my 6 speed swap and worked a treat.
For my prop, I shortened the E30 prop and welded the E36 flange onto the end of it.
rob_e30
« Reply #20 on: August 05, 2011, 11:44:36 PM »
Quote from: DaveM-sport;105952
Yep, that and a lot of time bleeding the clutch slave an that all worked great.
fumstoo
« Reply #21 on: August 06, 2011, 10:19:20 PM »
What clutch setup were you using with the g240s? just curious.
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #22 on: August 13, 2011, 08:36:20 PM »
Did you try an e36 propshaft? I always thought that was supposed to work.
-Nick
91 E30 M42 with VEMS
E30PQ
« Reply #23 on: August 14, 2011, 01:24:16 AM »
Quote from: fumstoo;105973
We run a Clutchmaster Stage IV clutch & pp that we picked up from Bimmerworld.
E30PQ
« Reply #24 on: August 14, 2011, 01:27:11 AM »
Quote from: NickHertlein;106095
We use the back 95% of an E30 prop shaft and and forward yoke (not sure if that is spelled correctly) of an E36 prop shaft.  Had a local drive shaft shop cut weld and balance the drive shaft.
DaveM-sport
« Reply #25 on: August 15, 2011, 06:03:10 PM »
Quote from: E30PQ;106101
Thats what I did. Cut and welded it myself with the help of the lathe though.
rob_e30
« Reply #26 on: August 17, 2011, 10:14:58 AM »
We lack the tools for this job, especially the balancing part.  IIRC it was only about $250 to have the shafts cut to spec and balanced with both shafts.
