Author Topic: Close Ratio trans, AKA E36/Z3 trans swap. Tell me more...  (Read 7095 times)
nickmpower
« Reply #15 on: November 05, 2006, 06:42:40 PM »
i'll probably get a 3.46 since .81 x 4.1 = 3.3
nickmpower
« Reply #16 on: November 18, 2006, 09:04:13 PM »
was your trans slightly longer then the stock one? and did you have to use a different selector rod?
romkasponka
« Reply #17 on: November 19, 2006, 10:37:46 AM »
Quote from: nickmpower;14042
yes it was, adjust your driveshaft CENTER MOUNT bearing max front.
http://www.realoem.com/bmw/showparts.do?model=AF91&mospid=47256&btnr=25_0026&hg=25&fg=05
selector rod was stock, but you have to instal part nr. 14 from your old gearbox.
p.s. To make short shifter the shift lever was modified, lower part was cut apart and peace of bolt welded in. Just make shure that gap between driveshaft and lever is about 1-2cm. And remove all plastic part when welding ;)
E30 318is M42
E36 318is M44
nickmpower
« Reply #18 on: November 19, 2006, 03:08:51 PM »
yeah. ive welded my x5 shifter already, though the clearence is definatly less then 1cm. Anyways, its good to know i have the right tranny! i just put a new e30 slave on but i havent used it at all so i think I am going to swap it for an e36 slave assuming the fittings are the same.
thanks
nickmpower
« Reply #19 on: November 20, 2006, 04:36:44 AM »
it looks like the tob arm needs to be different too
romkasponka
« Reply #20 on: November 20, 2006, 12:23:28 PM »
Quote from: nickmpower;14122
my tob arm is from E30 stock gearbox, but slave cilinder strut is custom made.
E30 318is M42
E36 318is M44
nickmpower
« Reply #21 on: November 21, 2006, 12:44:19 AM »
so you didnt use any think to secure it on the end oppside the slave like it has stock?
romkasponka
« Reply #22 on: November 21, 2006, 02:22:30 AM »
I used spring clip and ball pin from E36 gearbox.
http://www.realoem.com/bmw/showparts.do?model=BE51&mospid=47425&btnr=21_0140&hg=21&fg=05
part 6 and 7.
E30 318is M42
E36 318is M44
2002maniac
« Reply #23 on: January 12, 2007, 02:27:20 PM »
What are the ratios for 1-5 in this tranny?
nickmpower
« Reply #24 on: January 12, 2007, 06:44:45 PM »
search bimmer forums or something for them. I know that with my 3.46 1st will be longer and the rest will be shorter
