Author Topic: Power Steering hoses. PNs?  (Read 2550 times)
mikesjo
« on: September 26, 2006, 12:26:13 AM »
What are the part numbers for our power steering hoses? I've been told there are 3 hoses. What the part numbers are I don't know. I've looked on realoem.com and that diagram is confusing, I usually can figure things out but not this one.
Also, are the parts for a 325 power steering system the same for the 318is? Reason I ask is because bmaparts.com lists 3 hoses for the 325 but none for the 318.
Vladi
    • http://www.bmwzone.ro/forum
« Reply #1 on: September 26, 2006, 01:22:05 PM »
32.41.1.133.400 hose from the jar to the pump
32.41.1.133.401 hose from the jar to the rack
32.41.1.141.426 hose from the pump to the rack
mikesjo
« Reply #2 on: September 26, 2006, 01:41:54 PM »
Thanks!
« Reply #3 on: September 26, 2006, 04:58:55 PM »
$175 for a power steering hose. No way. I went to a hydraulic hose shop. They cut the banjo fitting, soldered their type compression fitting to it, and used their hose (same diameter). Cost $65. You can get all three done for the cost of the pressure hose alone.
