Author Topic: mtech1 steering wheel removal  (Read 4484 times)
318lotis
« on: October 16, 2010, 12:32:29 AM »
i found an m-tech 1 steering wheel in junk yard, perfect condition, no key, the 22 mm. bolt came out but wheel is locked up and will not come out, any suggestions??  thanx
« Reply #1 on: October 16, 2010, 07:07:55 AM »
If you figure this one out I'm interested...if you drilled the locking bolt out of the steering column or cracked the support pin you'd be set.  I've seen them pull the ignition lock with a big screw and a slide hammer (in the movies)...
Maybe a cutting wheel on the top of the lock mechanism could chop the lever that engages the steering lock?
YetiX
« Reply #2 on: October 16, 2010, 09:54:32 AM »
In the past, I have used a big flatblade screwdriver and a hammer.  Just slam the screwdriver into the key slot and turn.
-Scott-
\'91 318i 5spd
carlos318is
« Reply #3 on: October 17, 2010, 08:03:18 AM »
Quote from: YetiX;97544
Thats the best way:D
longtallsally
« Reply #4 on: October 25, 2010, 05:17:22 AM »
So how exactly did you know to do this....  :D
YetiX
« Reply #5 on: October 25, 2010, 12:07:15 PM »
Quote from: longtallsally;97889
That's how I took your car for a drive last year. ;)
-Scott-
\'91 318i 5spd
