Author Topic: H&R Sport Springs  (Read 12177 times)
Vladi
    • http://www.bmwzone.ro/forum
H&R Sport Springs
« Reply #15 on: April 04, 2006, 03:34:32 AM »
I've got blue H&R's from someone taking apart an e30 and nomal gas shocks+205/45ZR16 wheels. The stability is great for my demand. :D
318-is
H&R Sport Springs
« Reply #16 on: April 15, 2006, 05:59:56 PM »
i have just installed HnR 35mm springs on my Is without any other suspension mods (eibachs going on tomorrow) and the handling difference is noticable although i think could be greatly improved with the compliments of other mods (hence the ARBs). Despite this it sits at the perfect hight for a daily car.
im soon to be instaling sports bilsteins i hope so will let you know what the ride is like on Uk roads (which are crap). That set up is very well received over here though!
mikesjo
H&R Sport Springs
« Reply #17 on: April 15, 2006, 06:57:40 PM »
What are ARBs? Do you mind posting pics of your car with the new springs?
M42boy
H&R Sport Springs
« Reply #18 on: April 15, 2006, 09:18:58 PM »
Quote from: Febi Guibo
Hey, I am not all that familiar with spring rates (aside from booking hotel rooms in florida, lol) but I asked Drew at turner:
"The spring rates for the #29664 are about 200lbs (front) and 285lbs
(rear)."
The Sport vs HD really depends on what springs you run vs comfort.  I don't think the valving is very different (if at all), but you NEED to run Sports if you are using a lowering spring.  If not, you run the HD.  It's that simple.
I'm just supprised you got someone from Turner to talk to you.  Thier products and pricing is great.  I just wish thier sales reps understood the concept of customer service.  I've had negative experiences that would make your head spin!
« Last Edit: April 15, 2006, 09:23:04 PM by M42boy »
318-is
H&R Sport Springs
« Reply #19 on: April 16, 2006, 04:45:02 AM »
Quote from: mikesjo
ARB = anti roll bar, also known as stabalizers, make a masssive difference if you uprate them!
tim_s
H&R Sport Springs
« Reply #20 on: April 16, 2006, 05:07:27 AM »
hi dan. ARBs = 'sway bars' in US-speak
dan, put yourself up in the member's section...
« Last Edit: April 16, 2006, 05:19:10 AM by tim_s »
2.1 200bhp, 175ft/lbs 318is
E46 330ci daily
lordschleife
H&R Sport Springs
« Reply #21 on: April 16, 2006, 07:46:11 AM »
Quote from: 318-is
Hows the ride height compared to mine now Dan?
Cheers,
Robin
318-is
H&R Sport Springs
« Reply #22 on: April 16, 2006, 09:33:58 AM »
Slammed mate!
MattyK
H&R Sport Springs
« Reply #23 on: August 07, 2006, 08:41:33 PM »
Has anyone recently gotten the actual 50404, or does anyone know the spring rates on them? I know people have had problems getting them from turner and ending up with the 50404.55 which is no good. Anyone check with tirerack or bmpd to see if they have the true 50404?
Searching Ive found two spring rates for 'H&R sports', any they were both very similar (185/380 and 182/343 I believe) - so I think that those two are the same springs and people got different numbers from them, but I also think that those rates are for the 50406 springs for the 325/M3.
I think I'm still gonna go after the 29664's, but just looking for a bit more info about the alternatives...
My suspension redo.
« Reply #24 on: August 07, 2006, 10:58:27 PM »
Good to see someone else softening up  the car (compared to the usual mod setup) I've had it with the stiff spring/shock deal. I've got 350# fronts and 450# rears. It rides like a sled and skates on the bumpy curves - it is a rocket on the smooth ones though. My next project is to redo with 225# front and 350# rear. I'm putting M3 links on 318is struts. They make the bar quite a bit stiffer due to the bar movement being greater for the same wheel travel. The strut is an almost 1:1 wheel rate. The stock links are on the control arm a little over half way out toward the hub ball joint.
Sway bars are given way too little attention on E30's and are one of my pet peeves.
Don't get me started, you know how I get!
H&R Sport Springs
« Reply #25 on: August 08, 2006, 01:41:48 AM »
Quote from: D. Clay
actually, I'd like to know more about this...where do the links connect exactly on the the strut?
///Motorsport
H&R Sport Springs
« Reply #26 on: August 08, 2006, 10:48:29 AM »
i like my uber stiff ride... even on the bumpy sections of fast-driving road, (not bad road condition, i mean like bumps/jumps) the car feels like a racecar and its kinda fun to bounce a bit, assuming the shocks do their job and four wheels stay on the ground, as they normally do.  i wouldnt trade it for the world.  i need sway bars badly, they are next on the list, along with replacing each worn bushing..
M3 Sway bar brackets.
« Reply #27 on: August 08, 2006, 11:11:23 AM »
The mount brackets on an M3 are on the strut tube just below the spring perch and the links run up from the bar. On the regular E30, they run downward to the control arm.
http://e30m3performance.com/installs/GC_susp/GC_susp4.htm
This site mentions that they require reinforcement as they are prone to breaking on an M3 with a stiffer bar.
Here is another picture:
