Somewhat of a teaser...
Author Topic: Somewhat of a teaser...  (Read 9504 times)
The best.
« Reply #15 on: September 08, 2006, 12:33:28 PM »
Quote from: M42boy
You want to use silicone gasket sealant along with new gaskets when you put the timing cases back.
This stuff is the best. Wipes right off with an acetone soaked rag. Will seal Hewland and Weissman transmission cases without using any gaskets at all. It was sold under license by Permatex but they have discontinued it.
http://www.racerpartswholesale.com/ Look under "Complete Index" link.
http://www.hylomar.co.uk/Gallery.htm
Main site.
nickmpower
« Reply #16 on: September 08, 2006, 01:14:44 PM »
whats the advantage of m44 valves?
Febi Guibo
  • m42 reporter
« Reply #17 on: September 08, 2006, 02:20:55 PM »
Quote from: dude8383
i want a perfect seal!
jeez, you sound like a walrus...
m44 valves are a little lighter than M42 valves (smaller stems).
Support M42club.com !!
nickmpower
« Reply #18 on: September 08, 2006, 02:36:08 PM »
well is there any difference between the 6mm valve stem m42 valves and the 6mm m44 valves?
edit: i guess not  http://realoem.com/bmw/partxref.do?part=11341739820&showus=on
nickmpower
« Reply #19 on: September 08, 2006, 02:39:14 PM »
so are you using custom pistons or what?
« Reply #20 on: September 08, 2006, 05:48:10 PM »
s50 pistons :)
« Reply #21 on: September 08, 2006, 05:52:06 PM »
Quote from: nickmpower
part number for e36 m44 intake valve - 11341739820
part number for e30 m42 intake valve - 11341722908
Part numbers are different...so there has to be some difference!
silverblades181
« Reply #22 on: September 08, 2006, 06:28:43 PM »
So whats the plan? just increased displacement or is there more to it? do the S50 pistons increase or lower the compression?
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
nickmpower
« Reply #23 on: September 08, 2006, 06:57:53 PM »
well yeah the e30's have 7mm stems. I wanted to see if the 6mm m42 stems were different from the 6mm m44
« Reply #24 on: September 08, 2006, 07:09:52 PM »
Quote from: silverblades181
s50 pistons will increase compression...im shooting for at least 170 hp.
nickmpower
« Reply #25 on: September 08, 2006, 07:19:30 PM »
well are you incresing storke at all? i would think it would be hard to get 2l with just s50 pistons
« Reply #26 on: September 08, 2006, 10:31:05 PM »
yes of course! i have to increase stroke otherwise the pistons won't do what they're supposed to do.
I don't know what size, when i go to the machine shop ill make the dude give me the exact measurements that i need.
shellback
« Reply #27 on: September 09, 2006, 11:34:02 AM »
Quick question amigos:
Crank (M44 or M47) + S50 pistons will provide what kind of performance increase #’s? Trying to see how cost effective it would be to go that route or just slap on a DASC.
Thanks,
Chris
Febi Guibo
  • m42 reporter
« Reply #28 on: September 09, 2006, 12:12:10 PM »
M47 crank and S50 pistons will get you to around 180 hp (give or take) ...a dasc gets a little more, but the torque curve is much wider... there's a dyno sheet of the DASC install in the grassroots motorsports mag..
nickmpower
« Reply #29 on: September 09, 2006, 12:13:40 PM »
well the dasc was 189 i thought. and that was WHEEL hp
