Author Topic: Oil Viscosity?  (Read 7717 times)
Romrog318is
Oil Viscosity?
« Reply #15 on: June 03, 2010, 11:26:04 PM »
in the book it calls for 15w50 i always put 15w40 in mine and it was fine
i NEVER used synthetic and i still dont in my M52 unless i decided to spend the money and get ONLY redline which is the only synthetic i would even run! lol
no more M42
PumpItUp
Oil Viscosity?
« Reply #16 on: June 04, 2010, 04:25:48 AM »
Quote from: Sophia69IS;93168
I do not have any experience with synthetics. Your car does not leak at all?? I am very jealous. haha.
don't be too jealous, it's leaking coolant :rolleyes:
PumpItUp
Oil Viscosity?
« Reply #17 on: June 04, 2010, 04:53:02 AM »
My mechanic who has a bmw with nearly a million miles swears by Castrol 20-50 (conventional) on all German cars
everyone has an opinion. i reckon his experience is worth more than mine, but at the same time it's not a scientific study.
how come i never hear the important things discussed on car forums, rather than the usual
"shell is #1!! ya boi" type responses
like which oil keeps an m42 the quietest
before i had my e30 i took a nb miata for a spin. quite a few spins in fact :p by the time i brought it back to the dealer 10 mins later the lifters were screaming. maybe the best oils would have kept the mazda's mouth shut...:rolleyes:
so which oil keeps the m42 the quietest at idle, as well as after abusing it. :D
which burns the least, and which oil looks the cleanest? :confused: when you drain it, not the color on the dipstick because Kendall would lose straightaway
Oil Viscosity?
« Reply #18 on: June 04, 2010, 07:56:48 AM »
My engine runs nicely with the synth blend from the Wally World 5-qt jug.  Less cleanup too.
The oil is less important than the filter, IMHO.  I will go for the Pep Boys rebates because they usually toss in a free filter, especially if it's a Purolator PureOne.  I'm not sure of the Mobil1, even if they do carry a filter for our car.
I'd avoid the Fram because they might still be made from glued cardboard as in the past.  I've heard Wix and OEM are great too.
Oil Viscosity?
« Reply #19 on: June 04, 2010, 08:09:12 AM »
Quote from: Sophia69IS;93209
^ just 50W?
tjts1: what do you think of synthetic vs. conventional....i've heard bad things about switching on an older engine.
I used synthetic because I'm lazy. It allowed me to go twice as long between oil changes compared to conventional. The engine never leaked, never gave me any problems. At $5/quart and 7k oil changes, synthetic comes out cheaper than conventional oil.
Stick with Mahle or MANN oil filters.
« Last Edit: June 04, 2010, 08:15:02 AM by tjts1 »
BlueBMW
Oil Viscosity?
« Reply #20 on: June 04, 2010, 11:00:27 AM »
I use oem filters when I change mine.  With 5w30 synthetic BMW oil I seem to consume more but the motor is nice and quiet all the time... even with my shark teeth cam gears...
PumpItUp
Oil Viscosity?
« Reply #21 on: June 05, 2010, 05:49:00 AM »
i think bmw oil = castrol, bmw synthetic = castrol rs/edge or even better and only available in europe under castrol name
cristimm
Oil Viscosity?
« Reply #22 on: June 05, 2010, 11:55:26 AM »
Quote from: PumpItUp;93267
There are a lot of good oils out there. No need to blindly follow bmw's reccomandation (Castrol) just make sure you use the right grade oil.
seeohngee
Oil Viscosity?
« Reply #23 on: June 05, 2010, 02:20:51 PM »
I used 5-30 for the winter and I'm going to be changing to Pennzoil Gold 15w-40 in a few days.
