Author Topic: Oxygen sensor replacement  (Read 10255 times)
Systema
« Reply #15 on: March 14, 2010, 06:36:59 PM »
So I installed the new sensor, and everything went pretty smoothly up until I went to start the car. It started, sputtered out, and died. Now it won't start. It cranks, and it's getting fuel. Anyone know what could be wrong?
KenC
« Reply #16 on: March 14, 2010, 07:10:35 PM »
Quote from: Systema;89478
That has nothing to do with the O2 sensor. You touch anything else under there?  The O2 sensor only comes into play when you're up at operating temp.
Systema
« Reply #17 on: March 14, 2010, 07:13:29 PM »
^^^ That's what I figured, but I didn't mess with anything else so I don't know what could possibly have gone wrong.
Systema
« Reply #18 on: March 15, 2010, 08:33:40 PM »
UPDATE (Just in case anyone cares): Got the car running again, turns out it wasn't actually getting fuel. Bad fuel pump connection. I reseated the wires and everything seems okay on that front.
More importantly, the new O2 sensor fixed all of my problems! I had a really funky idle (sometimes it'd be near-stall low, and sometimes it would be up at 1500), stuttering/hesitation on acceleration, and loss of power all over the rev range, as well as a 1244 CEL code that would go on and off as I drove around. Since installing the new sensor, all of that's gone, including the CEL, which was starting to worry me. All fixed for around $45.
I hope this helps someone else who might be having the same problem as me.
cristimm
« Reply #19 on: April 01, 2010, 01:41:08 AM »
Quote from: RED IS 91;89170
As far as length goes just make it the same length as the one you take off.
I believe all bosch 02 sensors are the same.
Wire length says 37 inches.
I don't think that lenght of the wires is relevant. However the quality of the connections is.
KenC
« Reply #20 on: April 01, 2010, 12:46:30 PM »
Quote from: cristimm;90308
True.  The length of wire will only increase and decrease the resistance of the circuit, and since the resistance of copper wire is ridiculously low in the first place, a few inches longer or shorter is really negligible.
troman
« Reply #21 on: July 25, 2012, 02:50:35 PM »
I just did this with butt connectors, but I think I'm going to go back and re-do it with solder connections. I think the butt connectors might add too much resistance for what the sensor is spec'd for.
