Author Topic: Lost interior heat  (Read 7562 times)
BlueBMW
Lost interior heat
« Reply #15 on: February 11, 2010, 03:27:22 PM »
Here's a list from the SI bulletin.
13 12 1 180 237  Small Hose Clamp (10-16mm)   Qty 2
07 12 9 952 111  Large Hose Clamp (23-29mm)   Qty 4
64 11 8 391 926  Bypass Valve  Qty 1
64 21 8 367 834  Bypass Hose  Qty 1
64 11 8 367 832  "T" Piece  Qty 1
17 11 1 742 231  Radiator Cap  Qty 1
82 14 1 467 704  Antifreeze (1 gal)
iamcreepingdeath
Lost interior heat
« Reply #16 on: February 11, 2010, 07:27:10 PM »
ecalder, you may need a new PS pump.  and air bubbles aren't as hard to get out as people make them out to be.
batsbats
Lost interior heat
« Reply #17 on: November 10, 2012, 08:47:24 AM »
Really old thread revival, but wanted to make mention this graphic helped me solve my no heat problem.
I thought it was a clogged heater core, but after pulling this valve, I discovered it was the culprit.
batsbats
Lost interior heat
« Reply #18 on: November 10, 2012, 01:20:31 PM »
Quote from: batsbats;117541
On this topic, can anyone tell me if the bypass valve should trickle or flow freely?  When I was testing its flow with water, it dribbled out, a little heavier than droplets, but not completely free like I would imagine.
DRTE30
Lost interior heat
« Reply #19 on: November 15, 2012, 08:36:23 PM »
Oh my goodness...this thread...so so good.  That diagram may very well just save me wrestling out an old heater core and valve under the dash.  I have the updated lawsuit valve in my iS, and don't have heat at all- ever.  Good work OP!
Hey-u
Lost interior heat
« Reply #20 on: November 24, 2012, 01:42:41 PM »
I have the same problem and I think this thread just got my wife back into the vert.
