Author Topic: Our wires interchange with those of a Hyundai  (Read 6221 times)
flyinglizard
« Reply #15 on: April 09, 2010, 11:28:21 PM »
As stated, the jap wires dont fit the coils, or the plugs.  VW 16V may fit.  The coil pins need to be the small pin style.
 20 years of renting race cars
Rosales
« Reply #16 on: April 11, 2010, 01:47:32 PM »
Actually, I thought the same thing, but decided to gamble with the civic wires and it fires up the car fine.
bmwconnect
« Reply #17 on: April 11, 2010, 02:37:54 PM »
little off topic but I will be using Hyundai accent 2003 1.6L MAFs for my AFM to MAF conversion chip ;)
Midnight YouTube Channel
spanish_pants
« Reply #18 on: May 17, 2010, 02:53:33 PM »
Quote from: lqbanotxano;88565
Some of the Hyundai Accent wires don't work (I don't know about all) The ones at NAPA where $20.00 but did not work. The part that goes down into the head most be 4" long from tip to where it touches the valve cover. The Hyundai ends were 2-1/2" long only. Bad luck. I ended up putting Magnecor 8.5mm wires on. I did not use the guard that holds all 4 wires over the headers & cut the back of the plastic tray. The wires now go back & then go up then over to the OBD 1 plug harness then go over r to the coils. They don't go anywhere near the engine, or exhaust. The plastic BMW cover was retained. The Magnecor were about $105-$110 delivered. You can also get Magnecor 8mm for less.
Would you have any pictures?
