Author Topic: Oil Leak Persists!  (Read 5541 times)
FL318is
Agreed!
« Reply #15 on: August 16, 2006, 10:22:24 AM »
Just ordered a replacement.  Tried of playing with this.
Thanks
« Last Edit: August 20, 2006, 05:17:13 PM by FL318is »
FL318is
Oil Leak Update!!!!!
« Reply #16 on: August 20, 2006, 05:22:59 PM »
Hope this will help others with a persistant oil leak near the oil filter housing.
After many frustrating moments I think (:rolleyes: )  I got it fixed.
Solution: change the sensor and pray.
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_0506&hg=11&fg=30
Please note item 12.  Cheap and easy.  I highly recommend anyone with an oil leak near the oil filter housing change the sensor.  My engine is dry on that side now.
For the first time since I have owned the car ( 1 month) I was confident enough to drive it hard.
dbgrubbs
Oil Leak Persists!
« Reply #17 on: August 20, 2006, 07:40:53 PM »
I win !!!
Febi Guibo
  • m42 reporter
Oil Leak Persists!
« Reply #18 on: August 20, 2006, 09:42:39 PM »
hey! check post #2...  lol, switch, sender... same difference! :)
Quote from: Febi Guibo
if it's a little bit of oil, check the sender plug
Support M42club.com !!
FL318is
I am buying the beirs!
« Reply #19 on: August 21, 2006, 08:35:59 AM »
You guys are truely the best car club I have ever been in.  The fact that you are Bimmer heads has helped immensely.
As I go back over the posts I see the solutions where there.  So anytime I meet any of you the beirs will be on me.
BTW, I just walked out and opened the hood.  NO OIL LEAK and none on the pan!:)
