Author Topic: Take off/acceleration  (Read 6583 times)
quinn11m20
« Reply #15 on: January 14, 2010, 07:33:41 PM »
Quote from: wizard;84723
you mean you guys don't run these????
http://cgi.ebay.com/ebaymotors/supercharger-fan-turbonator-tornado-air-jet-fuel-saver_w0qqitemz170397597523qqcmdzviewitemqqptzmotors_car_truck_parts_accessories?hash=item27ac7cff53
all that extra power and fuel savings to boot....:d
are you fucking! Shitting me?!!!!
I wouldn't put that on my car to save my life. And I am important.
Chalino
« Reply #16 on: January 14, 2010, 10:35:19 PM »
Quote from: quinn11m20;84727
Suit yourself quinn ;)
1991 318is
2001 IS300
quinn11m20
« Reply #17 on: January 15, 2010, 07:51:14 AM »
True..I have seen all the Informercials.
The Turbonator. Some city in California put it in their fleet of vehicles and it improved gas mileage by like a whopping 2% on the lowest scale possible.
I am not driving spirited for fuel economy. Yeah I get great mileage but I dog the shit out of my car every time I get in her..
Well back to the daily grind..I have to figure out what else is wrong with her.
quinn11m20
« Reply #18 on: January 15, 2010, 01:33:47 PM »
Ok. I have an update.
Every thing is back in its place. ICV...Fuel pump relay..so on so forth.
I go to start the car and no Purge.. no sound is coming from the pump.
I remove the pump and test it outside by using jumper leads. It runs.
I replace the Fuel Pump relay with another relay in the fuse box. It must be that there is not the right resistance or something with the replacement.
So I use a jump lead to make the pump run constantly. This works.
It tells me that my relay is dead. So out to buy one.
I will keep you all posted.
quinn11m20
« Reply #19 on: January 15, 2010, 05:27:16 PM »
Update.
Went to purchase the relay, about $160. I found one for about $12 at advance auto. Didn't buy either. So its another week on the Harley.
Chalino
« Reply #20 on: January 15, 2010, 05:48:44 PM »
Quote from: quinn11m20;84808
Update.
$160 for a relay? WTF
1991 318is
2001 IS300
« Reply #21 on: January 15, 2010, 06:32:58 PM »
I thought the cheap Bosch relays all had the same pattern?  Some of the hits I get suggest diodes are installed in the FP relay.  I always carry spare FP & main relays in the glove box.
Are you sure the crank pos sensor is working?  Test the resistance on that plug & see if it's 'round 650 ohms.  If the CPS is bad it won't trigger the FP relay.  You might have a good one there.  Pelican sells those relays for like $15, don't they?  Not listed on their site, but I'm sure they'd mail one if you called.  BavAuto has them too, $8-$10 each.
