Oil was not at all milky. Compression is good.
--If I really have bearing shavings... what are the chances my crankshaft and rods are still salvageable?
--Is it possible to swap-out bearings from under the car... by pulling upper pan w/o pulling the motor?
Thanks again.
it really depends on alot a varibles, I have seen bearings go bad but the crank still look good, but I have also seen them ruin a crank. The last engine I tore apart, which is the engine that the bearing in the picture came out of, the crank needed to be reworked.
As far as doing it from underneath, It is possible but in the time it will take you to get the oil pan out, which in this car I think it requires the removal of the subframe, you may as well just pull the entire engine which takes me about 2 hours for the tranny and all. It isn't an extremely difficult job but there are a few things you need to remember to get it back together.
