Author Topic: Black Carpet... made easy  (Read 20325 times)
YetiX
« Reply #15 on: November 14, 2010, 12:47:40 PM »
Quote from: longtallsally;98649
And I forget, did you just use the spray stuff to do the do the vinyl areas?
Yes, just used the spray stuff on the vinyl.  Just have to be careful you don't use too much and get runs.
-Scott-
\'91 318i 5spd
dkbmxer002
« Reply #16 on: November 14, 2010, 02:37:59 PM »
to the OP, how did it hold up after a year? that is my biggest concern with doing this.
SimplyDope
« Reply #17 on: January 01, 2011, 09:34:19 PM »
I really want to do this bad now...
carlos318is
« Reply #18 on: January 02, 2011, 04:06:34 AM »
As soon as the the summer is here I will be doing this
Got to be one of the best mod ever
kaiser16
« Reply #19 on: January 18, 2011, 08:57:41 PM »
looks awesome, how about durability, do you guys see it fading or pieces of paint falling of after a while?
:D Freude am fahren! :D
O-Danger
« Reply #20 on: January 26, 2011, 11:15:38 PM »
Very interested into how this is looking now...
jrobie79
« Reply #21 on: March 03, 2011, 03:18:09 PM »
I used brydana colorbond product, the carpet stylin line with skid mark black as the color, i did this in probably late july early august and have not noticed any real fading or discoloration on either my headliner or carpet...
SimplyDope
« Reply #22 on: April 05, 2011, 02:54:32 PM »
I'm doing this right now. Using SEM ColorCoat. It's working out great so far. I'll get some pics up when everything is done.
carlos318is
« Reply #23 on: April 13, 2011, 04:00:43 PM »
Does anyone know if the carpet from a 4 door is the same as a coupe
YetiX
« Reply #24 on: May 02, 2011, 04:03:59 PM »
Quote from: carlos318is;103004
The front part is the same, sort of.  For the coupe they fill in the channels that the sedan's rear air vents go through with foam.  To use coupe front carpet in a sedan, just tear the foam out of the channels.  I don't know if you could use sedan front carpet in a coupe because the empty chanels would probably sag.
The rear bit is different, the sedan has longer wider "ears."
-Scott-
\'91 318i 5spd
carlos318is
« Reply #25 on: May 03, 2011, 01:34:12 PM »
Thanks mate
Brian318is
« Reply #26 on: May 04, 2011, 10:49:26 AM »
Any updates on this? How's it held up?
