Author Topic: Engine Bolts Torque Specs  (Read 13012 times)
badboypolar
« on: March 09, 2007, 04:20:28 PM »
I know this may be highly debated, however I will post it anyway. You can aruge till you are blue in the face, but these values are working just fine for me.
Head Bolts:
E12 Socket
Coat threads in straight 30 weight oil or assembly lube (i.e. Redline)
22 ft/lbs initial
61 ft/lbs final
Stretch type, replace if you ever remove the head
Main Bolts:
17mm; 6 point
20 ft/lbs initial
56 ft/lbs final
Rod Bolts:
10mm; 12 point
30 ft/lbs final
Flywheel Bolts:
19mm; 6 point
85 ft/lbs final
new bolts have thread locker on it, if reusing bolts apply Loc-Tite Blue to threads, be sure to clean the threads very well.
I replaced my clutch OE allen bolts with 6 point bolts for accessability reasons
Clutch Bolts
Replacement bolts I used:
thread is 8mm x 1.25
12mm; 6 point
25 ft/lbs final
For those who use stock bolts
Stock Bolts:
6mm allen
25 ft/lbs
Motor Mounts & Drive Shaft Nuts:
13mm; 6 point; locking nut
30 ft/lbs final
Be sure you use the locking nut type, otherwise you could loose your driveshaft.
Axel Bolts:
8mm allen
25 ft/lbs
« Last Edit: July 05, 2007, 01:30:57 PM by badboypolar »
forrer13
« Reply #1 on: November 20, 2009, 09:06:25 PM »
Are the Main Bearing bolts reusable? I have new connecting rod bolts but want to use the old Main bearing bolts.
