Author Topic: ICV interchangability  (Read 2473 times)
fiftytakedowns
« on: April 13, 2009, 07:16:28 PM »
Yes, I searched it, in three different forums.
I bought an ICV off of someone, and Recieved the E36 (Lshaped) ICV which I was not expecting.
IT has Tubes extending off of it which are larger than on my e30 T shaped ICV, so I Just barely get the Hoses over the ends. however the hose clamps didn't fit, so I called it quits, and reinstalled the *broken* one.
anyone have any experience with late model m42 ICV's on their E30's, do they even work? worth getting different hose clamps, and really forcing
fiftytakedowns
« Reply #1 on: April 14, 2009, 03:32:29 PM »
nobody?
fiftytakedowns
« Reply #2 on: April 15, 2009, 06:01:22 PM »
you serious?
romeomike
Some help from realoem.com
« Reply #3 on: April 26, 2009, 06:33:07 PM »
Still driving with my original ICV (91 318i)
Part 13411433627 (T-SHAPE IDLE REGULATING VALVE) was found on the following E30/E36 vehicles:
E30 318i Sedan, M42, MANUAL (AJ93) : Volume air flow sensor
E30 318i Convertible, M42, MANUAL (BA73) : Volume air flow sensor
E30 318is Coupe, M42, MANUAL (AF93) : Volume air flow sensor
E36 318i Convertible, M42, AUTO (BK63) : Volume air flow sensor
E36 318i Convertible, M42, MANUAL (BK53) : Volume air flow sensor
E36 318i Sedan, M42, AUTO (CC83) : Volume air flow sensor
E36 318i Sedan, M42, AUTO (CA63) : Volume air flow sensor
E36 318i Sedan, M42, MANUAL (CC73) : Volume air flow sensor
E36 318i Sedan, M42, MANUAL (CA53) : Volume air flow sensor
E36 318is Coupe, M42, AUTO (BE63) : Volume air flow sensor
E36 318is Coupe, M42, MANUAL (BE53) : Volume air flow sensor
E36 318ti Compact, M42, AUTO (CG63) : Volume air flow sensor
E36 318ti Compact, M42, MANUAL (CG53) : Volume air flow sensor
fiftytakedowns
« Reply #4 on: April 29, 2009, 01:28:12 AM »
Thanks, I put on the e36 ICV, and it did not help me whatsoever, problem still occured, so L shaped one is not compatible.
