when it's hot, roll a newspaper and stick it into the blades. if you can stop it with the rolled newspaper, your clutch is toast.
you can test it by stopping it get a towel or something, and try to stop the fan. when the engine is cold, it should stop easily... when it is hot, it should be difficult to try to stop it. if it stops easily, replace the clutch or just install electric fan
