My car wont pass smog for anything. the hydrocarbons are ridiculously high.
tonight, i just changed out what appears to be the original 130k mile o2 sensor. hopefully that will. help. i also replaced all the vacuum hoses. what a difference! i also rebuilt the head, new rod bearings all new seals, oil pan, front/rear main seals. car drives like a dream now. the car did have a blown head gasket when i bought it.
however, the idle still searches. it hovers around 900, which i found to be odd. so i shut the car off, and disconnected the ICV. started it up and it idles at 1500!! i looked at the throttle body and it seems pretty obvious what to do mechanically. but is there a certain procedure i need to follow?
