Author Topic: 1/2 instrument cluster back light out  (Read 3025 times)
Montanvs
« on: July 06, 2010, 09:36:33 PM »
Just wondering if anyone else has had an issue with the instrument cluster back lights?  Mine has half a side (right side) that does not go on......well sometimes it does.  Usually a tap on the dashboard lights it up fully.
It clearly is not the bulbs.  Loose connector?
1991 BMW 318is 170k, brilliant red
jscribble
« Reply #1 on: July 06, 2010, 09:44:31 PM »
Same deal for me. I like feeling like the fonz though.
Betty - Sold
Sabine - 2004 325xi
« Reply #2 on: July 07, 2010, 11:48:41 AM »
The three main bulbs share a pair of strip contacts that run across the back of the dash plate.  The three larger sockets unscrew and will accept a replacement wedge bulb.  Replace all three while you're in there, it's a pretty tedious job...especially if you still have an airbag.
Montanvs
« Reply #3 on: July 10, 2010, 08:04:27 PM »
since the bulbs seem to still work is it possible that some sort of corrosion has made the strip contacts intermittent?  The bulbs clearly still work at this point.
I dont have an airbag steering wheel, so should be easier to replace.
jscribble
« Reply #4 on: July 10, 2010, 08:23:49 PM »
It's just a bit time consuming, and while you have it all apart, it would be a good time to replace these bulbs. It's a few bucks vs a few hours of work if one goes out a week after you clean up the sockets.
Betty - Sold
Sabine - 2004 325xi
