I need injectors
Author Topic: I need injectors  (Read 3245 times)
Pedro
    • http://www.realoem.com/bmw
I need injectors
« on: July 24, 2006, 06:27:55 PM »
Obviously m42 injectors. '91 or else who has run other injectors besides stock? Anyone?
I need injectors
« Reply #1 on: July 24, 2006, 06:37:32 PM »
Curious here, are you experiencing any problems that lead you to believe that your injectors are faulty?
I need injectors
« Reply #2 on: July 24, 2006, 09:31:41 PM »
when i get my turbo on in the next few weeks I'll sell you mine if you don't have any by then.
Vladi
    • http://www.bmwzone.ro/forum
I need injectors
« Reply #3 on: July 25, 2006, 06:59:27 AM »
Asubimmer> Hopefuly you'll make a summery, at least, of the project. :rolleyes:
Euro Nation
I need injectors
« Reply #4 on: July 25, 2006, 01:18:01 PM »
If someone has the stock injector specs I can probably give you an easy junkyard source.
-Aaron
\'91 318i - Dead and gone
http://www.euronationvw.com
I own VWs... lots of them.
Pedro
I need injectors
« Reply #5 on: July 25, 2006, 01:36:41 PM »
Quote from: Eurospec
there is a thread where someone is showing a pic of there engine with a red arrow saying they have a fuel leak coming from there or around that spot. i also had a fuel leak at the time i pulled the motor out. i now have another installed but my leak was coming from right around the #2 injector. i cant be sure it would evaporate too quickly but the stain on the wiring harness was under the number 2 injector. i should get them flowed before i buy any but they are still stock from 91 and i know the previous owner put 87 or 89 in quite often. what are you thoughts?
Euro Nation
I need injectors
« Reply #6 on: July 25, 2006, 03:00:49 PM »
Go buy some injector o-ring kits.
-Aaron
I need injectors
« Reply #7 on: July 25, 2006, 03:53:29 PM »
yeah sounds like a seal, ie o ring.  but if you need some others, I'll have mine out soon enough ;)
Pedro
I need injectors
« Reply #8 on: July 25, 2006, 08:21:31 PM »
Quote from: Euro Nation
did that and leak kept on coming, which made me think it was a line but i couldnt find any cracks on the lines so i just ordered new ones and figured i might replace the injectors too.
what do you guys think?
