Author Topic: E30 & E36 difference  (Read 6686 times)
strypt
« Reply #15 on: April 18, 2008, 12:54:19 AM »
No vanos on the M42 nor the M44.
E30nate
« Reply #16 on: April 18, 2008, 01:17:41 AM »
Quote from: strypt;47398
i thought that any bmw after 94 had vanos?
Boyracer
    • http://www.jannousianen.net
« Reply #17 on: April 18, 2008, 03:42:38 AM »
Quote from: E30nate;47399
None of the 4 cyl BMW engines had VANOS ever I think.
E30nate
« Reply #18 on: April 18, 2008, 10:37:06 AM »
Quote from: Boyracer;47410
oh. well you learn something new everyday.
E30nate
« Reply #19 on: April 18, 2008, 01:18:45 PM »
so since the e36 doesnt have vanos, could i use the head from a 95 still, or would i have to use my stock one? and if i can use the head, will there be any gain from using the 91 cams in the 95 head?
strypt
« Reply #20 on: April 18, 2008, 02:36:48 PM »
Quote from: E30nate;47469
No problems using the -95 head.
Probably not noticeable which cams you'll use.
E30nate
« Reply #21 on: April 19, 2008, 12:48:37 AM »
Quote from: strypt;47476
ok. i probably wont bother changing them then. what about adjusting the cam gears. i know that advancing the intake side should give you a little bit of low end, but how much should i advance it if it do?
strypt
« Reply #22 on: April 19, 2008, 09:33:30 AM »
I haven't tested enough cam settings on the M42 to give you a good answer but play around with it a bit and clock some acceleration times and test yourself, then let us know ;) :)
E30nate
« Reply #23 on: April 21, 2008, 10:58:50 AM »
Quote from: strypt;47527
il probably do this. i need to find a cam degree wheel first though. il probably try harbor freight.
