Author Topic: Accelator pedal vs carpet removal  (Read 3230 times)
FL318is
« on: October 25, 2007, 12:10:54 PM »
Finally getting some time off.  Working on carpet removal.
So far so good.  I am trying to figure out 2 things.
1)  How to removal the acc pedal?
2)  Cutting the carpet under the heater/dash seems to be the easiest, but where do I cut?  Any diagrams?
Thanks.  I should have a beir whilst I ponder.
« Reply #1 on: October 25, 2007, 12:30:39 PM »
The pedal has wedgie type plastic retainers on the tab that goes through the carpet and into the floor. I pried the base of the pedal straight up with a screwdriver in several places and it snapped back in after reinstalling the carpet. You also have to take a clip off of the top and slide out the rod that goes through the firewall.
I cut the carpet after removing the console leaving the least amount I could under the A/C heater box. There was plenty to tuck back under the console.
FL318is
« Reply #2 on: October 25, 2007, 12:36:14 PM »
Thanks Clay.
Let the prying begin!
FL318is
« Reply #3 on: October 25, 2007, 11:02:22 PM »
I pryed and pryed.  Nothing except I think I am deforming the plastic.  Any suggestions?
